Old 07-12-2007, 11:37 AM   #1
Pressure Testing the Filter system, What meter to get?
I'd like to test the pressure drop through my filter system to see if it is overkill. What kind of meter can I buy to do this? Basically a barometer with a small tube that you can put thorough the sheet metal sounds like what I need. Do they make meters like this?
zootjeff is offline   Reply With Quote
Old 07-12-2007, 12:58 PM   #2
Agent 000
SecretSquirrel's Avatar
You can construct your own Manometer by using a clear plastic tube, stapled against a small piece of plywood, slightly filled with water... kinda the same thing as a water level. It's crude but you can measure the differential pressure by "Inches of water".
If you insist on buying one (a U-tube manometer) then Dwyer instruments can be purchased through Grainger & others. There's also Magnehelic gauges and so forth, but that's probably way overkill for your application.
SecretSquirrel is offline   Reply With Quote
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
Pressure testing methods currious Plumbing 6 04-07-2007 11:37 AM
Gas Line pressure testing standard(s) rolson6432 Plumbing 1 09-09-2006 03:33 PM
