Pressure Temperature Chart For Refrigerants - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 07:46 PM   #1
Question
Pressure temperature chart for refrigerants
Hi guys,
I have couple of questions.
1)The pressure values listed on this chart are suction pressure or discharge pressure?
2)Is the temperature listed is ambient temperature.
Thanks for your help!
Sam
Samart is offline   Reply With Quote
Old 04-17-2011, 07:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,234
What chart? Click on Go Advanced and follow instructions to upload a jpeg etc.
Old 04-17-2011, 07:58 PM   #3
I got the chart but what to understand the following:
Sam
Old 04-17-2011, 08:21 PM   #4
JJboy's Avatar
The temperature is related to the pressure. When the temperature changes the pressure increase or decrease.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 04-17-2011, 08:24 PM   #5
Thanks for the reply. I understand that, but not sure if the pressure values listed on the pressure temperature chart are suction pressure values or discharge pressure.
Old 04-17-2011, 08:49 PM   #6
So long as there's a saturated mix of both liquid and gas present it covers everything. Look at your chart and tell me what the R22 temp shows with a suction pressure of 60. Now look at the chart and tell me what it is on a 180 psig liquid line. How about a R22 tank with vapor and liquid in it at a room temp of 70 degrees?
Old 04-17-2011, 09:05 PM   #7
R22 shows 34 F at 60psi and 93F at 180psi. At 70F the pressur is showing around 120psi.
Please put some more light.
Old 04-17-2011, 09:30 PM   #8
I will wait for your response.
Thanks a lot
Old 04-17-2011, 09:56 PM   #9
JJboy's Avatar
Compressor does the change low pressure to high pressure. So the temp changes low to high temp..... What is your question?
Old 04-17-2011, 09:56 PM   #10
That's all there is to it,a relationship between pressure and temp for a given refrigerant. You have a system running 60/180. The suction line measures 50 degrees so how much is the refrigerant super heated ? The liquid line measures 80 which means you have what for subcool?
Old 04-17-2011, 10:04 PM   #11
I mean when to compare the pressure values on the PT chart with the actual suction pressure reading on the ac and when to compare with the actual discharge pressure reading
Old 04-17-2011, 10:14 PM   #12
I mean when to compare the pressure values on the PT chart with the actual suction pressure reading on the air conditioner and when to compare with the actual discharge pressure reading
Old 04-17-2011, 10:25 PM   #13
JJboy's Avatar
The difference between the temps that you are ​​measuring with a thermometer and the values ​​of PT chart are due to the SH and SC
Old 04-17-2011, 10:59 PM   #14
Does the temperatures on the PT chart indicate the ambient temperature or the pipe temperature?
Old 04-17-2011, 11:06 PM   #15
JJboy's Avatar
PT chart indicate the temp of the environment where is the refrigerant. The pipe temperature it's the measured temp
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 12:12 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
