-   -   Pressure temperature chart for refrigerants (http://www.diychatroom.com/f17/pressure-temperature-chart-refrigerants-101915/)
Samart 04-17-2011 07:46 PM
Hi guys,
I have couple of questions.
1)The pressure values listed on this chart are suction pressure or discharge pressure?
2)Is the temperature listed is ambient temperature.
Thanks for your help!
Sam
yuri 04-17-2011 07:50 PM
What chart? Click on Go Advanced and follow instructions to upload a jpeg etc.
Samart 04-17-2011 07:58 PM
I got the chart but what to understand the following:
Sam
JJboy 04-17-2011 08:21 PM
The temperature is related to the pressure. When the temperature changes the pressure increase or decrease.
Samart 04-17-2011 08:24 PM
Thanks for the reply. I understand that, but not sure if the pressure values listed on the pressure temperature chart are suction pressure values or discharge pressure.
Marty S. 04-17-2011 08:49 PM
So long as there's a saturated mix of both liquid and gas present it covers everything. Look at your chart and tell me what the R22 temp shows with a suction pressure of 60. Now look at the chart and tell me what it is on a 180 psig liquid line. How about a R22 tank with vapor and liquid in it at a room temp of 70 degrees?
Samart 04-17-2011 09:05 PM
R22 shows 34 F at 60psi and 93F at 180psi. At 70F the pressur is showing around 120psi.
Please put some more light.
Samart 04-17-2011 09:30 PM
I will wait for your response.
Thanks a lot
JJboy 04-17-2011 09:56 PM
Compressor does the change low pressure to high pressure. So the temp changes low to high temp..... What is your question?
Marty S. 04-17-2011 09:56 PM
That's all there is to it,a relationship between pressure and temp for a given refrigerant. You have a system running 60/180. The suction line measures 50 degrees so how much is the refrigerant super heated ? The liquid line measures 80 which means you have what for subcool?
Samart 04-17-2011 10:04 PM
I mean when to compare the pressure values on the PT chart with the actual suction pressure reading on the ac and when to compare with the actual discharge pressure reading
Samart 04-17-2011 10:14 PM
I mean when to compare the pressure values on the PT chart with the actual suction pressure reading on the air conditioner and when to compare with the actual discharge pressure reading
JJboy 04-17-2011 10:25 PM
The difference between the temps that you are ​​measuring with a thermometer and the values ​​of PT chart are due to the SH and SC
Samart 04-17-2011 10:59 PM
Does the temperatures on the PT chart indicate the ambient temperature or the pipe temperature?
JJboy 04-17-2011 11:06 PM
PT chart indicate the temp of the environment where is the refrigerant. The pipe temperature it's the measured temp
