Pressure Temp Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 10:53 PM   #1
Pressure temp question
Can someone explain what pressure temperature is exactly?
markharmon is offline   Reply With Quote
Old 05-21-2013, 11:07 PM   #2
Rewards Points: 616
in our trade temperature and pressure are directly related...... now grab a book and read.... I am way to old to explain it......
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
hvactech126 (05-22-2013)
Old 05-22-2013, 01:02 AM   #3
Look PT chart on line. It will give you the temp for any pressure.
subcool is offline   Reply With Quote
Old 05-22-2013, 09:41 AM   #4
Ok and when you set up your gauges to the system high and low side how do you know what temp/pressure your looking for?
Old 05-22-2013, 08:32 PM   #5
An old Tradesmen
Rewards Points: 8,202
mark. You said you went to an HVAC school or course. Didn't they go over any of this.
Old 05-22-2013, 10:11 PM   #6
i was told to use the gauges and a pressure temp chart and the pressure the system should be operating under. It was not a good school. Is this correct? I guess my question is how do I know if the reading is good or not?
Old 05-22-2013, 10:16 PM   #7
Rewards Points: 1,192
Not a good school or not a good student?
bobelectric is offline   Reply With Quote
Old 05-22-2013, 10:19 PM   #8
Not a good school. Can you please help me here. My one confusion is the usage of the pressure temp gauges.
Old 05-22-2013, 10:38 PM   #9
Something like look at the needle setting on the guage,(your pressure reading).Follow the needle to the freon you are measuring. (R-22) this your gas temperature.Something like that. Get the books out.
Old 05-23-2013, 04:31 AM   #10
An old Tradesmen
The readings will vary by the conditions of the individual day, and house.
The suction side reading will always have to be above 32 degrees. Get a super heat slide chart.
Study the books you got.
hydronic system pressure question - normal? johnnyzero HVAC 6 11-05-2011 11:30 AM
Pressure Switch Question loftezy HVAC 11 04-12-2011 04:57 PM
pvc pipe temp question? luckycockatoo Plumbing 2 09-08-2010 08:12 PM
Static pressure question Red Squirrel HVAC 1 07-15-2010 06:23 AM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 05:15 PM
