Old 01-24-2009, 09:19 AM   #1
Pressure switch stuck
Hello,
I have the Bryant Plus 90i and there is a code that just came up. It is code 23 (pressure switch did not open) It is telling us to check for obstructed pressure tubing - pressure switch stuck closed. The house is staying around 59 degress and with young children it n\makes me a little worried. Before I call someone to come out I wanted to see what I can find out with your site.
Thank you
SStein is offline   Reply With Quote
Old 01-24-2009, 09:29 AM   #2
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Turn power off. Usually does this when you remove the door. Pull the tubing off of your pressure switches (one at a time )and blow through them. Could've just got some trash in it.
wirenut1110 is offline   Reply With Quote
Old 01-24-2009, 09:31 AM   #3
Hvac Pro
In case the above post does not work out. It may be a faulty pressure switch or another bad issue. I have worked on lots of those units. Had a few where the port behind the ventor fan on the collector box got plugged with sulphur/smutz. Impossible for a DIY to fix as the entire ventor fan needs to be removed to get at it. I would call a Carrier/Bryant tech now B4 your house loses more heat. I would also go to HDepot and get a couple cheap $20 fan heaters for the kids rooms in case it takes a while for a tech to come out.
Old 01-24-2009, 04:26 PM   #4
I agree also to try and get some temporaryheat, uplug the heater and that will reset the board. While unplugged tap on the pressure switch a few times. If it is stuck this will loosen it and may work til a tech can get out there. The pressure switch is a round black or metal part usually at the top left of the heater.
A/C Williams is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 04:51 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Bad pressure switch? gshock HVAC 3 11-13-2007 08:15 PM
