Pressure Switch Replacement On Carrier 58STA110-22 - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 07:26 PM   #31
Rewards Points: 588
I had another company come out and diagnose the problem.
Turns out it's a faulty control board. The board makes the blower fan run constantly, even after you disconnect the t-stat. Also, no voltage is going to the inducer motor when the heat is called from the t-stat. And the status LED no longer lights up. The list goes on and on. The tech tested the T-stat terminals on the control board and said the t-stat was sending the correct signals to the control board. Kind of a bummer since the board was replaced this past summer. (do these control boards fail this often?) The company that incorrectly diagnosed the problem to be the pressure switch and then tried to charge me $550 to install it is the same company that now refuses to honor the warranty on the control board they put in this past summer. Nice huh?
Anyways, my plan is to swap it out for a new board tomorrow which I was able to attain. Does this board look wired correctly right now (see pics above)? Because I plan on plugging everything into the new board just like everything is plugged in right now.
Thanks again for all the help.
noone is offline   Reply With Quote
Old 12-04-2012, 08:14 PM   #32
An old Tradesmen
Rewards Points: 6,116
Looks like its wired right.
Old 12-05-2012, 06:43 PM   #33
Rewards Points: 588
Arrived with the new board only to discover the blower was humming loudly, locked up.
Went back and picked up a new motor then drove back and installed the new control board and blower motor.
Everything is now working.
Thanks for everyone's help.
Strange pressure switch problem jones814 HVAC 24 01-16-2012 11:24 AM
Carrier Bryant plus 355MAV, Furnace - pressure switch calibration fault mnpugguy HVAC 1 10-21-2011 07:42 PM
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
Weatherking pressure switch stuck closed error code bobnorman76 HVAC 0 12-18-2010 10:29 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
