Pressure Switch Replacement On Carrier 58STA110-22 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 07:56 PM   #1
Rewards Points: 590
Pressure switch replacement on Carrier 58STA110-22
I need to replace the pressure switch on a Carrier 58STA110-22. Is this fairly easy? Will I be able to buy this part at my local Johnstone Supply? Thanks in advance....
noone is offline   Reply With Quote
Old 11-19-2012, 08:45 PM   #2
Jeeze...
Did you even call the Johnstone to find out? Might have a generic but Carrier is really only the place to get them.
hvaclover is offline   Reply With Quote
Old 11-20-2012, 01:38 PM   #3
Rewards Points: 590
My A/C repairman just called me back and told me it was $550 for the switch. This does NOT sound right. I thought I heard these were around $50? I think I'm getting jerked around here.
Old 11-20-2012, 02:17 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,312
You are. But most companies will travel to your house and install it for $200 and up and we don't care about what the consummer finds out the price is. My boss called a customer who supplied a certain product after finding out his cost on the internet. When asked if he would drop his price because we know his cost. No way in h**ll so why should we give away our services.
Old 11-20-2012, 02:28 PM   #5
Rewards Points: 590
Is there any way to rig it to work temporarily? Maybe blow in the tube to clear it out?
Old 11-20-2012, 03:26 PM   #6
Hvac Pro
yuri's Avatar
No, It works off vacuum.
Americanhvacparts.com. Click on pressure switches or phone them as they have most brands and switches.
Old 11-20-2012, 04:25 PM   #7
Rewards Points: 590
I just ordered the switch from my local Carrier distributor for $21.
Just curious- do these switches malfunction often? The unit is only 7 years old.
Old 11-20-2012, 05:00 PM   #8
Pressure switches rarely fail. Unless you measured the vacuum with a manometer to know for sure the odds are against it.
Old 11-20-2012, 05:08 PM   #9
Rewards Points: 590
What is the likely culprit then? The LED light flashed in sequence 3 short and one long. I did notice that it was hard to blow into the black tube that was attached to it (I had to blow really hard for air to pass through). What is this tube connected to?
Old 11-20-2012, 11:57 PM   #10
JJboy's Avatar
By this error code the problem is in vacuum not on the pressure switch......The pressure switch doesn't fail open and close at the same time.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 11-21-2012, 12:05 AM   #11
Rewards Points: 590
Any tips on how I can fix this myself?
Old 11-21-2012, 12:13 AM   #12
JJboy's Avatar
You need manometer to check if the inducer motor is pulling the vaccum pressure necessary to close the pressure switch....also you can check for any clogged at the exhaust. Using a multimeter you can measure if there is 24vac at the pressure switch when the tsat call for heat.....when you see the igniter glow you should get 0v at the pressure switch.
Old 11-21-2012, 12:22 AM   #13
Rewards Points: 590
Thanks. The inducer motor never comes on. Is that because of the pressure switch? I'm not sure how the black vacuum tube connected to the pressure switch works and what the other end is connected to. Thanks again for the assistance!
Old 11-21-2012, 05:47 AM   #14
The inducer should come on first then the pressure switch closes. No power to the inducer would be a bad control board. Yes power but the inducer doesn't run equals new inducer assembly or a bird stuck in the wheel.
Old 11-21-2012, 06:12 AM   #15
Rewards Points: 590
Interesting. They just replaced the control board over this past summer. Are there any gotchas to replacing the control board? Is it possible they didn't hook up a wire to the correct place? What can I check?
Strange pressure switch problem jones814 HVAC 24 01-16-2012 10:24 AM
Carrier Bryant plus 355MAV, Furnace - pressure switch calibration fault mnpugguy HVAC 1 10-21-2011 06:42 PM
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Weatherking pressure switch stuck closed error code bobnorman76 HVAC 0 12-18-2010 09:29 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
