Pressure Switch Rating Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 09:00 PM   #1
I have a Criterion II with a bad pressure switch and bought a replacement at the end of winter last year. I didn't get around to even opening the package til today (didn't need it).
Looks like they sent me the wrong one. I bought it on eBay, so I am not going to bother trying to return it. I will either get another one or use this one. So, here is my question:
The switch my furnace uses is a .45 and the one I bought is a .35. I installed the "wrong" one and it worked, but took it back out and put the original back in becuase I don't know if the "wrong" one will cause damage.
Should I use the .35 or am I crazy?
danbeall is offline   Reply With Quote
Old 11-04-2010, 09:07 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,136
You need the higher rated original one or it will be UNSAFE to use. The pressure switch measures/proves the proper amount of safe draft thru the furnace and if it is not enough shuts it down. A lower pressure switch will fool it into thinking it is safe to use when it is not.
The Following User Says Thank You to yuri For This Useful Post:
danbeall (11-04-2010)
Old 11-04-2010, 09:13 PM   #3
On second look, I had the numbers backwards.
The "wrong" one is .45 and the original is .35. I am going to assume it is still unsafe to use the .45.
Old 11-04-2010, 09:19 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Going a little larger will be ok
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-04-2010, 09:24 PM   #5
Huh.
Maybe that is why they sent it... because it is an "acceptable" replacement. I will probably use it, at least temporarily.
Thanks!
Old 11-04-2010, 09:29 PM   #6
Hvac Pro
yuri's Avatar
Usually the exhaust fan can produce up to 1" WC suction so .45" will be okay .
.35" is the minimum suction but they usually produce 2X that when working properly or they would be tripping all the time. I would order a .35" from a reputable dealer and not necessarily from the "great unknown" market which could be used or whatever parts.
Old 11-04-2010, 09:32 PM   #7
That makes perfect sense to me. Thanks for the explanation.
Looking forward to sleeping through the night without waking up, feeling cold, then going to the basement to tap the switch
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 04:51 AM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 06:56 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 12:16 PM
