Pressure Switch Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2007, 09:15 PM   #1
I know my pressure switch is good, but there is not enough pressure to trip the switch. The hose too it is not blocked, and I pulled the induction motor and there is no wind (checking with match) so I am guessing the heat exchanger is good. My vent is clear, pulled at an elbow to check.
What could cause not enough pressure?
jamespappin is offline   Reply With Quote
Old 10-28-2007, 02:32 AM   #2
HvacWiz's Avatar
Rewards Points: 252
Have you tried checking the port hole on collector box that the hose connects to, these often get plugged up as well.
HvacWiz is offline   Reply With Quote
goodman pressure switch error 3 blinks mrbac HVAC 4 03-11-2013 11:43 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 10:41 AM
What engages pressure switch? dfferg HVAC 1 09-12-2005 10:27 PM
