Pressure Switch Problem?
I know my pressure switch is good, but there is not enough pressure to trip the switch. The hose too it is not blocked, and I pulled the induction motor and there is no wind (checking with match) so I am guessing the heat exchanger is good. My vent is clear, pulled at an elbow to check.
What could cause not enough pressure? |
Have you tried checking the port hole on collector box that the hose connects to, these often get plugged up as well.
| All times are GMT -4. The time now is 01:47 AM. |
