Pressure Switch Error Code - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 10:14 PM   #1
pressure switch error code
I have a g50uh furnace and it shows proper light code for heat demand> 2 slow flash green. It spins up the inducer and that is all. after about 2 minutes it shuts off and gives me a pressure switch error. where is the pressure switch?
eagle5202 is offline   Reply With Quote
Old 11-17-2011, 10:30 PM   #2
Eagle, the pressure switch is a safety switch that monitors the flues, and drains if its a condensing furnace.It seems like thats all we have talked about all week on here......but anyway a pressure switch error code means that one of several things or a combination of these things could be wrong.
1. a blocked exhaust and or intake
2. a plugged or restricted condensate drain
3.a bad inducer motor
there are many many other scenarios that could be an issue, but this is a start. Now as far as were the switch is on your furnace, post a picture with the doors off and I/we can point it out, if you are able to do so.
harleyrider is offline   Reply With Quote
Old 11-18-2011, 05:23 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 154
mid eff unit. switch is above ventor fan. remove it and VERY carefully remove the red tube so it does not crack. poke a paper clip or small drill bit thru the hole on the ventor fan.
Old 11-18-2011, 09:14 AM   #4
pressure switch cured.
Thanks for your help guys.
I removed it and cleaned out the orifice. Bingo.
21 deg last night, fifty in my office when I got it running.
Cool....I mean HOT!!!
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Well Pressure Switch Replacement (Photos) porkfriedrice Plumbing 4 10-27-2011 04:31 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
