Pressure Switch Error - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 09:36 AM   #1
Pressure switch error
I am getting a pressure switch error when either you use the heat pump or when you use emerg heat setting which uses propane. Hose to pressure switch is clear is their a way to check both pressure switchs to see if their bad? This is a Americian Standard Variable Speed 2-Stage furnace
phoneman77 is offline   Reply With Quote
Old 11-15-2010, 01:44 PM   #2
HVAC / Plumbing
You can check them with vm
kenmac is offline   Reply With Quote
Old 11-15-2010, 04:19 PM   #3
I did this, 1 way you get resistance when you suck on hose you hear switch and it goes open on resistance on vom
Old 11-15-2010, 05:14 PM   #4
An old Tradesmen
Rewards Points: 8,236
Should close when you suck on it.
The Following User Says Thank You to beenthere For This Useful Post:
phoneman77 (11-15-2010)
Old 11-15-2010, 05:31 PM   #5
I have alos noticed that the vent fan never comes on and when I checked for voltage at the fan I'm not getting any. talked with a tech who said should get 115v so I thank that the control card may be bad.
Old 11-15-2010, 05:45 PM   #6
An old Tradesmen
Could be a bad board.
goodman pressure switch error 3 blinks mrbac HVAC 4 03-11-2013 11:43 PM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 02:04 PM
Comfortmaker RPJ - 3 Flashes - Pressure Switch Contacts Open olgranddad HVAC 9 02-21-2009 03:07 PM
