Old 02-11-2010, 11:07 PM   #1
pressure switch connection problem
Is there a way to check the wire connection to the pressure switch? the swich itself is good but only works when laying on the floor, not mounted. i am assuming its the connection. Lennox ghr26.
thank you,
wayne
wayfis is offline   Reply With Quote
Old 02-12-2010, 02:41 AM   #2
An old Tradesmen
Trashed your other thread. Please don't make duplicate threads, thank you.
Your pressure switch is probably fine.
The tech should have checked to see how much pressure it was sensing.
You may have a restricted vent.
Pressure switch issue? or something else... rp4985 Plumbing 8 07-11-2009 03:31 PM
Pressure Switch Stuck Closed --heat works but A/C doesnt assassinmunky HVAC 0 06-23-2009 03:49 PM
Wierd 3-Way Swirch Problem. Armitage Electrical 3 02-22-2009 08:52 PM
Comfortmaker RPJ - 3 Flashes - Pressure Switch Contacts Open olgranddad HVAC 9 02-21-2009 04:07 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 01:35 AM
