Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 11:40 AM   #1
Rewards Points: 236
pressure switch
i am having ongoing troubles with my pressure switch.
furnace model # tappan/nordyne L1RA 072C 12B
the trouble is the electrical connection. i can mess around with it and get the furnace running again. i had to last night.
so i want to get a new one, and terminals.
i am looking at them. there are part #'s that are close to mine. but they have different color "dots" on them. what do these mean and are they interchangable ?
i am thinking not, but just asking.
nordyne pressure switch 632432
http://www.google.com/search?q=nordy...w=1066&bih=598
while i am at it. can you recommend replacement that i can buy ? to have on hand, for the next failure. i am looking at the HSI. but what about the sensors ?
yeah, i know i asked this before. but i am asking again.
Fix'n it is offline   Reply With Quote
Old 01-26-2014, 12:29 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,858
Not sure what the dots are. It MUST match the OEM specs and that has to do with the " inches water column WC rating. also the mounting can be a problem if you do not get the OEM part. try americanhvacparts.com
if you get it from Nordyne the inches WC may be slightly different and that is OK because they have tested it and got it approved for the gas code and UL.
The Following User Says Thank You to yuri For This Useful Post:
Fix'n it (01-26-2014)
Old 01-26-2014, 07:58 PM   #3
I looked at different images and looks like it does coincide with different pressure ratings for the switch. So make sure you order one with same rating / "w.c. To prove the fan is operating and flue is moving the desired c.f.m. (Cubic foot of air per minute) of air.
Focused2 is offline   Reply With Quote
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
