Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 06:10 PM   #1
JJboy's Avatar
Pressure switch
Do You guys know if all pressure switches on negative pressure, If I tighten the hose will shuts down the gas valve? Does any pressure switch will maintain negative pressure and not close the gas valve?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Well Pressure Switch Replacement (Photos) porkfriedrice Plumbing 4 10-27-2011 04:31 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
