Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 05:37 AM   #1
Pressure Switch
Is there a way to test the pressure switch to see if it is bad?
Bryant 383K gas furnace.
DADDY31 is offline   Reply With Quote
Old 01-17-2008, 06:11 AM   #2
Union HVAC Tech.
Printed on the switch is the pressure it closes/opens. You need to install a tee fitting in the line to the switch and connect a manometer or magnahelic to the tee. Turn off the fuel to the unit. Then turn on the unit and read the pressure on the gauge. If it makes the printed units the switch should change state when read with an ohm meter.
If not, the switch is bad. Remember, there is a positive and negative side to all pressure switches.
bigMikeB is offline   Reply With Quote
goodman pressure switch error 3 blinks mrbac HVAC 4 03-11-2013 11:43 PM
Bad pressure switch? gshock HVAC 3 11-13-2007 07:15 PM
Pressure Switch Problem? jamespappin HVAC 1 10-28-2007 02:32 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
RUUD Gas Furnace Pressure Switch? erik11 HVAC 8 12-06-2006 11:39 PM
