Pressure Switch? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 01:36 PM   #1
Pressure switch?
Hi guys,
with pressure switch hose connected the blower attempts to run, but wont. When i disconnect the hose the blower runs but furnace wont ignite? Is it a bad ps
jbenetat is offline   Reply With Quote
Old 10-02-2011, 01:54 PM   #2
biggles's Avatar
tail is wagging the dog there if your talking about a heating cycle on the furnace the tube is waiting on the Induced Draft to run then it proofs the PS then the burner cycles on as lonf as the PS is sensing air pressure from the ID...when the stat calls the furnace in the ID is the first thing to run the rest is staging for the main burner..should have 2 low voltage wires connected to the PS remove one and touch it to the other you should hear the spark ingnition click and lite it proofs out and the main gas comes on to heat ...the onlt thing that controls the ID is the stat calll
Old 10-02-2011, 02:38 PM   #3
thats what i meant, the id runs but only if i disconnect the hose to the ps. so then the ps is no good. when i jump the ps connections, the id shuts off
Old 10-02-2011, 03:10 PM   #4
JJboy's Avatar
Use a multimeter to test it....don't guess
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-02-2011, 03:19 PM   #5
biggles's Avatar
you missed the "tail wagging the dog"comment...the PS is a proof from the ID to run the heat,not the other way around thinking the PS runs the ID...stat runs the ID PS proves air is present into the chanmber the ignition sparks and the gas runs something is mis wired the wires that go to the PS have nothing to do with the run of the ID
Old 10-02-2011, 04:23 PM   #6
biggie, if the id wont run with the ps connected , what do i check?
Old 10-02-2011, 04:59 PM   #7
biggles's Avatar
i don't know something is mis wired..how many wires are connected to that PS
Old 10-02-2011, 05:25 PM   #8
An old Tradesmen
Rewards Points: 6,142
Brand and model number of furnace would help.
Old 10-02-2011, 05:34 PM   #9
York 80 , it worked at the end of last season. Mod# pickd16n09601a.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 08:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Carrier gas pack won't ignite, pressure switch doesn't close TNFrank HVAC 3 12-02-2010 05:42 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
