Pressure On The Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 05:06 PM   #1
Pressure on the furnace
It sounds like the furnace wants to kick on but the pressure says it's high and the other low. No heat of air is pushing through the vents what do I do?
azdcoast is offline   Reply With Quote
Old 10-05-2010, 05:17 PM   #2
HVAC / Plumbing
have someone check the pressure with manometer
B-4 you edited the post.. Didn't you say something about gas pressure too high ?
kenmac is offline   Reply With Quote
Old 10-05-2010, 05:32 PM   #3
If it sounds like it's trying to come on it does it for about a minute or so but no air cones out through the vents what should I do?
Old 10-05-2010, 05:54 PM   #4
Seasoned DIYer
Rewards Points: 150
Atomospheric pressure is measured electronically, mechanically or traditionally with a column of mercury, but with static pressure and gas pressure involving HVAC, its usually measured in W.C. or inches of water, so rig up something with a plastic bottle and clear tubes incised with a marker on height from surface of water and you have nearly 100% accurate manometer.
HVAC_NW is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
