-   -   Pressure on the furnace (http://www.diychatroom.com/f17/pressure-furnace-83146/)
azdcoast 10-05-2010 05:06 PM
It sounds like the furnace wants to kick on but the pressure says it's high and the other low. No heat of air is pushing through the vents what do I do?
kenmac 10-05-2010 05:17 PM
have someone check the pressure with manometer
B-4 you edited the post.. Didn't you say something about gas pressure too high ?
azdcoast 10-05-2010 05:32 PM
If it sounds like it's trying to come on it does it for about a minute or so but no air cones out through the vents what should I do?
HVAC_NW 10-05-2010 05:54 PM
Atomospheric pressure is measured electronically, mechanically or traditionally with a column of mercury, but with static pressure and gas pressure involving HVAC, its usually measured in W.C. or inches of water, so rig up something with a plastic bottle and clear tubes incised with a marker on height from surface of water and you have nearly 100% accurate manometer.
