Pressure Drop Value For Commercial Air Diffuser - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 08:35 PM   #1
Rewards Points: 150
pressure drop value for commercial air diffuser
I am calculating friction rate loss for some ductwork I may do but I am having trouble locating the EL value for a commercial size air diffuser. If I had a copy of Manual Q , I may find the answer. Anyone know what's the EL value of the air diffuser in my picture? It is the air diffuser in the middle top side of the picture. 2ft by 2ft air diffuser.
thanks
-kilo
kilosos2 is offline   Reply With Quote
Old 01-05-2013, 09:27 AM   #2
An old Tradesmen
Rewards Points: 6,836
Diffusers/registers are not assigned a TEL. they have PD rates.
EG: .03", or .013" at X CFM.
If that is a Hart&Cooley HV grille, their website has the engineering specs that will list its PD for different CFMs. You then use the PD value of the CFM you need as one of the devices you subtract from your units rated ESP to get your ASP.
The Following User Says Thank You to beenthere For This Useful Post:
kilosos2 (01-06-2013)
Old 01-06-2013, 05:47 AM   #3
Rewards Points: 150
Thanks BT! I was expecting the answer most likely coming from you!
Thanks again
-Kilo
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Water pressure drop using two fixtures Mpr193 Plumbing 2 11-21-2011 07:28 PM
Pressure drop after replacing faucet seat plumbing_noob Plumbing 5 10-25-2010 09:14 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
