President - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2014, 02:13 PM   #1
klnergaard's Avatar
Rewards Points: 24
President
pressure switch error code on freedom 90 furnace.
klnergaard is offline   Reply With Quote
Old 09-14-2014, 06:35 PM   #2
An old Tradesmen
Rewards Points: 6,544
Was the inducer running. Did you check for a blocked flue. Moisture in the pressure switch hose?
Old 09-15-2014, 08:23 AM   #3
klnergaard's Avatar
Rewards Points: 24
Keith
Inducer is working, flue screen is clear, all tubes are cleaned out, found a few bugs in 2 of them, just 2 drops of water in pressure switch line also cleaned out pvc drain lines.
Old 09-15-2014, 08:32 AM   #4
klnergaard's Avatar
Rewards Points: 24
Smile
Keith
I also checked for voltage on pressure switch (24v) and continuity. I have to blow in pressure switch to get furnace going. It runs fine, but wont start up on its own after calling for heat again.
Old 09-15-2014, 04:01 PM   #5
An old Tradesmen
The switch cold be defective. or the heat exchanger could be cracked, or the induce not getting up to full speed.
If you have a manometer you can check and see what pressure the switch is receiving.
Old 09-15-2014, 06:05 PM   #6
klnergaard's Avatar
Rewards Points: 24
I went on the roof today and dropped a 25 ft. tape down and it read 23 ft. when I hit bottom. I then cut the pipe in the basement and ran the tape up for 23 ft. I could not feel any obstruction from either direction. I could also visually see the 90 degree bend at the bottom. It was also clear. I also removed the remaining piece of pipe going to the furnace. It was also clear. I put a 2 inch rubber boot or coupling and joined the pipes back together. The furnace started 3 times in a row and seems to be working just fine. I will let you know if it quits. Thanks for all the help. Keith
A few jokes... gma2rjc Off Topic 3615 Today 12:12 AM
US President to address the country unscheduled on a Sunday night. Leah Frances Off Topic 87 05-09-2011 07:33 PM
Trump for President? bernieb Off Topic 23 04-30-2011 03:47 PM
Actual U. S. Debt-200 TRILLION H. A. S. Off Topic 21 11-06-2010 02:55 AM
