Premier Horizantal House Furnaces In California - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 10:08 AM   #1
Premier horizantal house furnaces in California
Hi Team,
Do we have a problem with horizontal attic mounted house gas furnaces ? specially the ones that are made by consolidated and / or premier furnace companies ? and if so how often you come across them ?
Thanks for your input
Wilson Golpashi is offline   Reply With Quote
Old 12-30-2011, 10:45 AM   #2
Rewards Points: 484
Originally Posted by Wilson Golpashi View Post
Hi Team,
Seems like we had quite a few in the Hesperia/Victorville area when we lived there, if I'm thinking of the right brand, they had major heat exchanger failures.
sammy37 is offline   Reply With Quote
Old 12-30-2011, 10:57 AM   #3
Sammy 37,
Can you pleaase explain heat exchanger failure ? My neighborhood is full of these furnaces and in last ten years mine worked very well. Are we talking about an isolated case blown out of proportion ? or do we have a problem? Thanks for your input.
Old 12-30-2011, 11:00 AM   #4
Rewards Points: 484
Sammy 37,
How old is the furnace? The ones I've seen were out of houses built in the 80's. As far as heat exchanger failures, just your typical cracks and such.
Probably wouldnt hurt to have it inspected.
Old 12-30-2011, 11:06 AM   #5
My house was buit in 1996, I bought it in 2001 and since then had no problem. I do have annual inspection done on the unit and so far all is good. No signs of cracks, etc. Will re-inspect it myself again.
Old 12-30-2011, 11:10 AM   #6
Rewards Points: 484
I cant say if you have a problem, I just remember many contractors complaining about how poorly they held up.
Old 12-30-2011, 11:12 AM   #7
Rewards Points: 484
They may have worked the bugs out on their newer models. Seems like every brand out there has had a heat exchanger problem somewhere along the line that they have had to rectify along the way.
Old 12-30-2011, 11:14 AM   #8
Rewards Points: 484
I'm curious, why the concern?
Old 12-30-2011, 11:31 AM   #9
Rewards Points: 484
I just googled premier and found that there is a page dedicated to a recall issue with them concerning nox rods and fire concerns but it stops at 1994, so maybe yours is not an issue.
The furnace is almost 15 years old, you should consider just replacing it.
My house progress so far - over the years Snav Project Showcase 5 05-06-2015 11:11 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 09:39 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
