#1 |
DIY'er
Powervent Size / Distance
Hi,
I'd really like to change where my PVC power vent exits the house for my High Effic,80,000 BTU Goodman furnace. However, I don't know what size pipe needs to be used for the distance I want to run, and how you compensate for elbows and such. I just need a chart that tells me this info and I can calculate out my distance and loss from elbows / turns. I get the call your dealer type of thing from Goodman, so they are no real help. I can't find a chart or guide like this online. I know I've worked with charts like this in the past for other plumbing applications, things like for a sump pump. Thanks Jamie
Jamie Dolan - Neenah, WI To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Need Help Uploading Photos? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#2 |
Start by getting the installation manual for your furnace. It should state what restrictions you must follow such as size, lengths, number of elbows, TEL, etc.
#3 |
Hvac Pro
Post the model and serial # here. We have some Goodman guys here who may have a link to their manuals,
#4 | |
DIY'er
Powervent Size / DistanceQuote:
Here is the model CAPF3642C6AA Thanks Jamie
#5 |
Hvac Pro
Are you sure of that model #. Most of the high eff Goodmans I have seen are GMNT or something similar.
#6 | |
DIY'er
Sorry. I bet that is the coil. I guess im not awake yet. I will go look again and respond shortly, Thanks Jamie
#7 |
DIY'er
Ahh had to unscrew the cover...
GMV950704CXBA Output 66,900. Thought it was a 80,000. Thanks very much Jamie
#8 |
Hvac Pro
Powervent Size / Distance |
#9 | |
DIY'er
Thanks again, Jamie
| Display Modes | |
| Size of whole house fan needed | Doug Crf | General Discussion | 20 | 02-26-2011 12:29 AM |
| pre-hung door, 32x80 is that door size or total size? | RyanD | Building & Construction | 3 | 06-28-2009 11:33 PM |
| duct work size | justmefixin | HVAC | 2 | 09-20-2008 07:59 PM |
| Wire size and Breaker size for remodel ?? | Skydmark1 | Electrical | 12 | 12-15-2007 06:00 PM |
| Wire size for distance Question | fburke | Electrical | 4 | 07-28-2007 10:29 AM |
