Power Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 08:17 PM   #1
power vent
I have two gas furnaces side by side.- for main floor and basement. The flue pipes for each are 4inches each going into 6 inch double wall flue pipes that goes to a power vent and then to side wall. The power vent pie going to out side is 4 inch. This installation has been working without problem for over 5 years.
My question is - is it required to change 4 inch power vent to 6 inch and will that meet code ? Or is it required to have separate 4 inch power vent for each furnace ?
d.c.patel is offline   Reply With Quote
Old 04-27-2011, 09:02 PM   #2
An old Tradesmen
Rewards Points: 7,328
The power vent has to be rated for the total BTU of both furnaces. Plus, it needs to have an interlock control so that neither furnace can run if it fails.
Ridge Vent and Power Vent? etern33 Roofing/Siding 7 06-06-2011 07:06 AM
Ridge vent and power vent neikorott Roofing/Siding 1 09-09-2010 05:57 AM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Noise from boiler power vent den HVAC 2 03-03-2007 07:10 AM
