Power Gas Heater With A Generator? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 10:39 AM   #1
Rewards Points: 302
power gas heater with a generator?
I have gas heat. So in my basement, there is a unit. I hear it come on and the flames literally fire up inside. Then the blower comes on to move the heat into my home.
Say our power goes out. I assume with no power to the thermostat, that tells the heater to shut off.
But what if I had a generator? Couldn't I power the blower/air handler and/or electrical parts of the gas heater itself, effectively putting normal heat back into my house during a power outage?
I think my thermostat is connected to the unit and powered via a thin wire. Then I believe there is only one line of romex running to the entire heating unit - I could be wrong.
But you get the idea here.
If this were totally possible, I assume then the next question would be how many watts would it draw?
If it's like 2000 watts or less - a small space heater takes up that entire amount. So why not use the normal system?
denemante is offline   Reply With Quote
Old 02-12-2014, 12:29 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
a furnace takes roughly 4 amps x 120 volts = 480 watts. the problem is unless you get a high quality generator with an electronic governor/speed control the frequency of the power will vary from 58 to 62 hz and that can damage the circuit board. there are whole home generators that have that but your basic Honda portable one does not. they are designed for power tools. the power needs to be a steady 60 hz. I have a expensive electronic power conditioner that I bought from an electronics store for around $300 to use with my Coleman generator. Not the same as what you buy for a stereo (Monster) from a stereo shop either.
Old 02-12-2014, 04:23 PM   #3
An old Tradesmen
Rewards Points: 6,934
A 1/3 HP blower motor will use about 500 watts. But takes alot more to start it.
Warning Against Doing Dryer Outlet Generator Hookups Arnold Ziffel Electrical 19 11-02-2012 07:11 AM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Pipe vibration from power vent water heater cerfsud Plumbing 4 01-10-2012 06:39 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Water Heater on Generator capt2 Electrical 5 01-03-2008 08:48 PM
