Power Aprilaire 700 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 08:33 PM   #16
An old Tradesmen
Rewards Points: 7,274
Its not too hot for it.
The EAC terminal is for an Electronic Air Cleaner.
Old 10-08-2012, 08:52 PM   #17
Rewards Points: 16
Chris 43 is offline   Reply With Quote
Old 10-09-2012, 05:51 PM   #18
Rewards Points: 16
Just wanted to double check.
The water valve wires are 18 gauge copper braided.....do I need to use low voltage wires for these two brown wires...one wire is going to the transformer and the other to the stat.
How can you tell a low voltage wire from a non one?
I know all the hook ups for the stat. control to the furnace board and the sensor are all low voltage....I have purchased the brown stat. cable with 5 wire inside for that.
Thanks again
Chris
Old 10-09-2012, 06:04 PM   #19
An old Tradesmen
18 gauge is for low voltage.
Old 10-09-2012, 06:50 PM   #20
Rewards Points: 16
Thanks beenthere.
I know where to hook the transformer up to now, but I'm guessing I have to purchase a box to put it in.
The transformer that came with the 700 is only "box mount" one and I have no room in the other one.
Is installing a box the only option I have with this transformer? I can mount it...inside or on the outside of the furnace....here a pic of transformer.
Chris.
Old 10-09-2012, 06:58 PM   #21
An old Tradesmen
Top off the box in the furnace has a knock out that you can mount the transformer to.
Old 10-09-2012, 07:01 PM   #22
Rewards Points: 16
No room...They ran gas line out there, just to the top of the box
No choice but to add one right?
Old 10-09-2012, 07:43 PM   #23
An old Tradesmen
Add one. or drill a hole in the side of the furnace whee the box is, and mount the transformer on the outside of the furnace.
Old 10-09-2012, 08:16 PM   #24
Rewards Points: 16
Hey thanks for the quick replies beenthere
If I mount it on the exterior witch I can. The transformer would be uncovered on the exterior of the furnace...is that ok? should it not be housed in something or is it that the low voltage would not harm anyone if touched.
Chris
Old 10-09-2012, 08:30 PM   #25
An old Tradesmen
Low voltage doesn't need to be housed.
The Following User Says Thank You to beenthere For This Useful Post:
Chris 43 (10-09-2012)
Old 10-10-2012, 05:43 PM   #26
Rewards Points: 16
Can someone tell me what the broken line "C" is for. see pic.
[IMG][/IMG]
Chris
Old 10-10-2012, 05:50 PM   #27
An old Tradesmen
Common to thermostat is optional on some thermostats.
Old 10-10-2012, 05:52 PM   #28
raylo32's Avatar
Rewards Points: 1,282
Your thermostat may or may not need to be connected to the c terminal. Self powered (battery) or old school mercury stats need no c-wire connection. If you have a wifi stat or one that otherwise needs external power, it would get it through the c-wire (makes the circuit from r to c back to the transformer). In either case it has nothing to do with your humidifier.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-10-2012, 08:36 PM   #29
Rewards Points: 16
Thanks very much guys.
I do have a wire on the "C" terminal of the furnace board. I will wire it as per the diagram. I will wire the outside sensor and put the water line in tomorrow....coming along nicely.
Chris
Old 10-11-2012, 06:07 AM   #30
raylo32's Avatar
A tip for the water connection: don't use the silly saddle valve, they are prone to leakage. Install a tee in a water pipe and put in a proper shutoff valve, preferably a decent ball valve. Then add the necessary adapters to the valve outlet to connect the humidifier water line up to. If you want a little neater water line you can get a premade icemaker line at the hardware or appliance stores. I have one with the stainless mesh overwrapping and premade female connectors with rubber seals. They come in several lengths.
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
