Ok, I changed my mind...just moved the receptacle from the power vented hot water tank over a few feet and both the Humidifier and the hot water tank blower fit...power to the Humidifier fan done!
FYI Furnace is a Luxaire...about 7 years old.
Next... The two brown wires coming from the bottom of the humidifier that power the solenoid.
I understand that they need 24v . I have a empty HUM and EAC. Also two empty neutrals...but I'm guessing that its not going to hook up to any one of these, not sure thou....here's a pic of my board.
IF not.....I have the 24v transformer that came with it....Should this be mounted inside the furnace near the junction box and then the black/white wires from the transformer feed into the junction box for power, or should this transformer be outside the furnace to save it from heat....here's a pic
What about the gauge of wire...18 gauge is coming from the solenoid valve...is that what I should use to run it from the water valve and back to the humidifier control via the transformer?
I know alot of questions lol...I really dont know much about this stuff, and like learning....and saving money.
Thanks again for your time.
Chris
