Possible To Convert Hot Air Heat To Water Circulating Radiators - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 05:29 PM   #1
Question
Possible to convert hot air heat to water circulating radiators
Is it possible to convert hot air heat to a water circulating radiator system?
Dennis
djtjak43 is offline   Reply With Quote
Old 01-11-2009, 06:20 PM   #2
You must hire a plumber to run the piping all around your house. Either a baseboard or radiator setup you need the hot water pipes. Also, obviously a new boiler.
thelimit is offline   Reply With Quote
Old 01-11-2009, 08:21 PM   #3
An old Tradesmen
Rewards Points: 6,112
Possible, and expensive.
But, often times, a more comfortable heat.
Old 01-11-2009, 08:58 PM   #4
Is there a reason to convert? You could also look into hydronic heat where you can keep the duct work and have a boiler for hot water.I put this in the addition on my house, it works really well. I got to have central a/c and I have a 80 gal hot water tank.
Plumbvoltage is offline   Reply With Quote
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 07:15 PM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
hot water radiators computergranny HVAC 2 02-01-2008 07:06 PM
