Originally Posted by Davecg2
Thanks everyone. I thought it would be ok, but wanted to make sure before I ordered it. Since the part looks a little different is there anything I need to pay attention to as far as which wires go where or is it going to be pretty obvious?
I think I remember that being a 3 wire switch form looking it up. That basically means there are 3 terminals to hook wires to. Should be labeled NC (normally closed) NO (normally open) and C (common). The old switch should be labeled the same way, just make sure to write down wich wires go where on the old switch & put them in the same places on the new switch.
If it only has 2 terminals then it shouldn't matter which wire goes to what side.
