Portable A/C In Windowless Room - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 05:10 PM   #1
Rewards Points: 41
Portable A/C in windowless room
Have a converted garage, that cant keep cool. A supply duct was added during the conversion, but doesn't seem to help much.
Is a portable A/C even an option with no window out there?
Thanks for any/all suggestions
dbower is offline   Reply With Quote
Old 08-23-2011, 05:20 PM   #2
JJboy's Avatar
I have the same configuration....Portable A/C 12000BTU is not working properly in the Texas summer. You need at least 2T If your garage is insulated
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-23-2011, 05:21 PM   #3
Rewards Points: 41
The garage is insulated.
You're windowless as well? Where do you vent the exhaust?
Old 08-23-2011, 05:29 PM   #4
Rewards Points: 380
Ductless split is the answer you are looking for. If you need heat through other seasons make it a heat pump for not much extra $.
HVACDave is offline   Reply With Quote
Old 08-23-2011, 05:32 PM   #5
JJboy's Avatar
Yes, I made a hole in the wall.
Old 08-23-2011, 06:22 PM   #6
An old Tradesmen
Rewards Points: 7,318
Might want to see if getting a return to the converted garage helps it. A supply running to there with no return reduces the amount of air that can get to that room.
Old 08-23-2011, 08:52 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
That's the issue I'm having in my own bedroom. If the land lord is good with it I'm going to add a small (6") supply and one return, or upsize the existing 8 to a 9 x 7 x 7. The only return this old house has is a single 20 x 25 on the lower wall in the hallway. My room stays a few degrees warmer than the living room.
Doc Holliday is offline   Reply With Quote
Old 08-24-2011, 04:20 AM   #8
An old Tradesmen
If the door isn't under cut, a return will make a big difference.
Old 08-25-2011, 05:20 PM   #9
newtech's Avatar
Rewards Points: 164
May I ask why he needs at least a 2T unit?? No specs were given to the size of the space or the location...
newtech is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
First Question: How to cool this room? Warhammer: 3025 HVAC 4 03-25-2009 10:02 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
