Old 10-07-2010, 05:55 PM   #1
Portable AC in basement, no place for exhaust....
I was wondering if I could use a Y joint where my hot water heater and HVAC exhaust go to the roof vent, to be able to tie in my exhaust for my portable AC unit? There are no windows in the room that I am trying to cool and I do not want to heat the rest of my basement by simply cooling one room. Any suggestions on what to do? Thanks
Atlanta4 is offline   Reply With Quote
Old 10-07-2010, 06:02 PM   #2
No you can not tie any vent to a furnace or water heater flue. Drill through to the outside.
Old 10-08-2010, 03:31 PM   #3
I am currently growing Shiitake mushrooms in the room I am trying to air condition. This is only a temporary hobby which lasts about 11 weeks and I do not want to drill to the outside of the house. Any other suggestions?
Old 10-08-2010, 04:43 PM   #4
steveel's Avatar
Assuming you figure it out, I think you propose to cool a basement room without cooling the rest of the basement. Are you building a condensation or mold problem (a) between the rooms walls and the basement foundation or (b) on the walls that partition this room off from the rest of the basement?
steveel is offline   Reply With Quote
Old 10-08-2010, 06:47 PM   #5
An old Tradesmen
Over heat the other basement room/rooms.
Or stop growing mushrooms.
Since we can't see your basement. A drawing of its layout would help.
Old 10-08-2010, 08:14 PM   #6
hvaclover's Avatar
You can rent water cooled acs. All you need is a water supply and a floor drain.
But tell me, I thought mushrooms needed high humidity to grow. The ac wil de humidify the air.
Isn't that going to interrupt your project?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 09:31 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Leaky Basement Advice JRMN Plumbing 6 12-18-2009 06:45 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
