Popping Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 02:05 PM   #1
Popping Vents
This is my first time using the heat in the house I moved into and the vents in the master bedroom "pop". The noise is coming from underneath the floor and I am pretty sure the floor will have to be taken up to resolve the issue. Any ideas on the best way to go about this or advice on my diagnoses of the problem.
For whatever reason, HVAC contractors are unwilling to perform the task which leaves me to complete the job. Thanks in advance for your advice!
Mr. Yango is offline   Reply With Quote
Old 10-08-2012, 04:48 PM   #2
An old Tradesmen
Rewards Points: 7,356
Pull the register and see if you can move the duct/pipe.
The Following User Says Thank You to beenthere For This Useful Post:
Mr. Yango (10-10-2012)
Old 10-08-2012, 05:04 PM   #3
how
Rewards Points: 1,104
A couple of alternatives.
I assume you are talking about an air pressure change causing the ducting to "pop" under your bedroom floor. It's not a choice for everyone but setting up your heating system with continuous or a 2 speed blower system will often stop the duct "pop" sound.
Sometimes just going from a regular filter to an allergy filter reduces the air pressure enough to make a difference. A temp rise test across the furnace is best established if choosing this route.
Are many of your other outlets dampened down and thereby causing more air pressure into the Master Bedroom outlet?
Are you sure its a heating duct and not a return air vent?
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 10-10-2012, 07:52 PM   #4
It is definitely the heating ducts and it seems to be the temperature change rather than the pressure change. If I installed dampers in the basement to cut off the flow, does that typically work? It is a second floor bedroom so heat is actually not an issue. Thank you for the help!
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 10:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 05:18 PM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
