"pop" Sound When Last Burner Lights - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 11:29 AM   #1
"pop" sound when last burner lights
I have a carrier unit (forced air)- there are 5 burners in the chamber- I watch the first 4 light with no issue- the 5th one is delayed in lighting and then when it does it shoots the flame outward and makes a pretty large pop sound- then it lights..... what could be causing this?
crazyskiier is offline   Reply With Quote
Old 10-16-2010, 11:38 AM   #2
The little slit ,crossovers, on the face of the burner has something in it. Pull all the burners out and clean them up good.
Old 10-16-2010, 11:59 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
What is the model #. Some of those Carrier burners you need to take out and flush with hot water in the kitchen sink to clear out the crossovers slits and the internal passages. Especially the 2 stage units that fire at a lower pressure.
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 09:05 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
comfortmaker pilot lights but not burner jasonzzz HVAC 6 01-28-2008 11:20 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
