Old 07-22-2007, 04:52 PM   #1
mjb
Poorly insulated plenum
I have an upflow furnace in a hall closet with a coil on top from the late 80's. The coil is in a poorly constructed sheet metal plenum with an insulating blanket around the outside of the plenum. There is no type of insulating material on the inside of the plenum.
The blanket is in pretty bad shape and the front is uncovered sheet metal since all of the insulation has been removed a few times for service of the coil. The heating vent pipe runs right in front of the plenum so it won't be easy to get a blanket back in place, which is probably why it the blanket torn up so bad.. Any ideas on how to best insulate this plenum? Can I buy an insulating material and 3M spray adhesive to properly insulate the inside?
mjb is offline   Reply With Quote
Old 07-23-2007, 10:25 PM   #2
Mechanical Contractor
Yes, maybe 1/2" armaflex sheet material or something similar.
MechanicalDVR is offline   Reply With Quote
Old 10-15-2008, 02:33 PM   #3
DO NOT INSULATE INSIDE PLENUM! This could possibly cause a fire. If you want to insulate, insulate the outside only. I recommend ceramic insulation. Try Unifrax PlennumWrap. Can be purchased online at
Last edited by Termite; 10-15-2008 at 04:20 PM. Reason: Site rules violation. Advertising link removed
BobVilla is offline   Reply With Quote
Plenum - Where to buy? zootjeff HVAC 1 07-11-2007 09:21 PM
Condensation blowing off A coil into plenum kona1406 HVAC 6 05-26-2007 08:50 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 06:38 PM
Upgrading can lights to insulated? juliejules4 Electrical 2 12-03-2006 05:25 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
