Poor Flow Of Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 01:40 PM   #1
Poor flow of cold air
Hi all,
I'm trying to repair a York air con which has been blowing not so cold air. I've checked the pressure of coolant and it's 130 psi. I'm not sure what it is supposed to be as it is an older unit and my tech lit on it is long gone. Is this necessarily a coolant problem, or could the vents be blocked somehow?
Thanks for any help
RR
Red Robin is offline   Reply With Quote
Old 07-22-2012, 01:52 PM   #2
biggles's Avatar
make sure the coil inside is clean both sides,filter is clean squirrel cages are clean..in fan section...130PSI seems like r-22 what is the temp around the condenser out side whil it is running...and i take it that was the thin copper line out on the condeser you hooked up guages...sounds short.don't add any fron till the air side is checked inside....seeing any ice on th insulated line at the air handler or out on the condenser insulated line going in?check the condenser info tag for actual freon.do you have freon to charge it.the fan speed should be HI in cooling or the same as if you shut the system at the stat and do FAN/ON...
Old 07-22-2012, 02:16 PM   #3
If it is R22, 130 is not right for either low or high side pressure. Better call a tech to check the charge.
clocert is offline   Reply With Quote
Old 07-23-2012, 10:26 PM   #4
130 psi means the compressor is not running the fan may be but not the compressor.
turnermech is offline   Reply With Quote
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 03:39 PM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 06:50 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
