Pool Heat Pump - Fan In Reverse? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 01:15 PM   #1
Rewards Points: 160
Pool Heat Pump - Fan in Reverse?
I have a Hayward pool heat pump, model HP 2100, that is about 8 years old. Earlier this year, it worked for about a week, then stopped working and displayed a "Sensor Failure" code. I was busy and on the road for work so I left it alone for about three weeks. I finally found the repair number but before calling I tried it one more time and it worked. Go figure.
So it's been working for about a week now. Last night I was doing yard work and went over to it to cool off from the cold air that blows out the top of the unit. To my surprise, the fan is now running in reverse and sucking in air from the top! It is still heating the pool.
Any ideas on what is going on here?
cgoll is offline   Reply With Quote
Old 06-22-2012, 03:49 PM   #2
An old Tradesmen
Rewards Points: 6,464
Either a failing motor, or a failing capacitor.
Old 06-22-2012, 03:54 PM   #3
Rewards Points: 160
Thanks for the reply. Not sure how either would affect fan motor rotation direction, but I'm no expert in this area.
Do you think I am causing more harm in letting it run this way? It is still heating the pool.
Old 06-22-2012, 04:13 PM   #4
An old Tradesmen
It may be heating it some, but not as much as it should. Its making the ompressor work harder then it should have to. So may be shortening the compressor life span.
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 05:14 PM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
