Polyurethane Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 01:21 AM   #1
Polyurethane ducting
ADVANTAGES USING POLYURETHANE DUCTING COMPARE TO SHEET METAL DUCTING
1.More safety against fire , fire retardant B1
2.Excellent, constant thermal insulation thanks to the high density Polyurethane (52 +/- 2kg/m)
3.Light Weight. Polyurethane ducting weight 1.46kg/m compared to 9.8kg/m sheet metal duct
4.Silent operation, vibration and reverberation are minimized, increasing system comfort
5.Hygienic and does not absorb humidity
6.Air tight seal, very low air leakage, the leakage test result is only 0.98m/h.m
7.Simple and easy but highly productive fabrication and installation
8.Easy maintenance and modification can be performed on site, cut and gluing can be applied in any section of the ducts.
9.Excellent appearance and long lasting, life expectancy are 20 years.
wikanti is offline   Reply With Quote
Old 01-28-2008, 05:53 AM   #2
Union HVAC Tech.
Funny, I never saw sheetmetal burn.
That's one point.
Never seen an install that anyone cares what the metal weighs.
No better than a lined metal system.
Doesn't matter with wrapped duct.
No better than a properly installed sheetmetal job.
Have to see.
There goes your duct design.
are 20 years.
I have seen many metal jobs 40 plus years old that don't need replacement.
So are you just spamming? Sounds like a sales pitch to me.
bigMikeB is offline   Reply With Quote
Old 01-28-2008, 06:14 AM   #3
General Contractor
joasis's Avatar
Besides, HVAC techs will decide what they install, this is not typically a DIY task.
BTW, I have seen the new ducting, or old, depending on strict definition, and it goes in for under floor (slab) installs here.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 01-28-2008, 06:19 AM   #4
Union HVAC Tech.
joasis, good point. I just hate sales pitches.
Removing Polyurethane Overspray for cars paint finish... Norm Automotive Repairs 5 05-25-2014 08:58 PM
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
Applying polyurethane with a pump-up sprayer handymanII Painting 3 10-17-2007 04:01 PM
Insulating A/C ducting ? Scott_K HVAC 1 10-04-2007 07:21 PM
Water in Furnace Ducting sdoca HVAC 3 09-14-2007 07:54 AM
