Old 10-05-2012, 02:35 PM   #1
gkaro's Avatar
Polaris water heaters
I see from research that the Polaris water heater is a great option for using a combi dhw and space heater. Can't seem to find whether the side taps are connected to a dedicated heat exchanger or whether they are open to the potable water.
I'd like to avoid mixing the two systems.
Otherwise I would have to use a plate exchanger and more circs.
Any advise would help...
gkaro is offline   Reply With Quote
Old 10-05-2012, 03:50 PM   #2
Just checked online. It appears that some Polaris (Navien) water heaters are equipped with dual heat exchangers. Might be of more help if model number given.
techpappy is offline   Reply With Quote
Old 10-05-2012, 04:10 PM   #3
gkaro's Avatar
Thanks but navien (tankless) heaters Re not related. The units I'm talking about are high eff tank units by gsw or John woods.
Any opinions on using a water heater for dual purpose??
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 04:57 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
