Pointy Self Tapping Screws For Ducts? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 07:41 PM   #1
Rewards Points: 1,456
Pointy self tapping screws for ducts?
I'm helping a friend do some ductwork in his basement, but can't find the screws we need. When I redid mine I just used what the builders had used. I was lucky enough I didn't need more. They were pointy and would easily get through the outer duct and pull in the inner crimped duct. I went to Home Depot and couldn't find the same type so I bought self tapping screws, but they take 45 seconds of pushing before they go through the first duct and then just crumple the inner duct. I returned those and bought sheet metal screws, but they also won't get through. I've come to the point where I am going to use one of mine to make the hole, remove it, and then insert the other screw. Please somebody tell me what I'm looking for, it's driving me crazy. They were also great because they fit into my impact driver with no bit. Thanks.
mikegp is offline   Reply With Quote
Old 06-02-2013, 08:04 PM   #2
Rewards Points: 282
something like these:
self tapping sheet metal screws
self drilling sheet metal screws
jmon is online now   Reply With Quote
Old 06-02-2013, 08:04 PM   #3
Rewards Points: 6,652
Same aisle as the rest of the screws and nails in Ace Hardware. Lowe's, Home Depot, Menard's seem to have the bad habit of placing self tapping sheet metal screws in the duct work aisle, not where you would think that they should be, and that is with the rest of the nails and screws.
I swear that half the time, they change aisles at our local Lowe's and Menard's about every six months, just to screw with people, where stuff is. One trip the product is in the aisle you would expect it to be in, next trip it is in a totally unrelated aisle with no rhyme or reason why they moved the product.
Old 06-02-2013, 08:25 PM   #4
Jmon, first link doesn't work. Second link are the screws I tried and they just crumple the inner pipe. I quickly checked in the duct section and didn't see them. I'll try next time. Wish I could have a link to show them when I go.
Old 06-02-2013, 08:26 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by mikegp View Post
Please somebody tell me what I'm looking for...
self drilling sheet metal screws. #6 x 1/2"
Don't forget to get the mastic to!
LINK to pictures
Old 06-02-2013, 08:55 PM   #6
Rewards Points: 282
Fixed first link sorry mike.
Old 06-02-2013, 08:57 PM   #7
Tarheel, those are the ones the crumple the inner pipe. The ones I want look like a regular screw, but they're very pointy and the first two threads are narrow. I still have mastic from my project, but haven't checked if it's still good.
Thanks for the help so far.
Old 06-02-2013, 09:01 PM   #8
Thanks, jmon, but still none of those are pointy. The ones that look like a drill bit aren't cutting it and the ones that just say sheet metal aren't pointy enough. I tried both.
Old 06-02-2013, 09:05 PM   #9
The duct sheet metal is too thin. Just tape the joint with foil tape, then spread the duct mastic over it and be done with it.
Old 06-02-2013, 09:14 PM   #10
The pointy screws go in like nothing. I just wish we could find those.
Old 06-02-2013, 09:25 PM   #11
Again, they are in the same aisle in your local Ace Hardware with the rest of the screws. Otherwise you have to hunt for them in your local Lowe's or Home Depot, but they have them also. It also helps to get the drill going at a high enough speed and letting the screw do the work, not by pushing it into the duct.
I have used Self-Taps on thin gauge duct work with no problems. It sometimes help to just use a small high-speed drill bit to drill a pilot hole, then just screw the self-tap in enough to where you can finish hand tightening. It takes practice, but you do it enough, you can get them in with no problem, no matter what the gauge of the sheet metal is.
It comes out usually a end-user issue, not a device issue, why these things never go how you want them. Personally I like using tape over screws on stuff like duct work, then use mastic, because then you have nothing to cause whistling as the air flows through the duct.
Old 06-02-2013, 11:20 PM   #12
Experienced HVAC Tech
HVAC1000's Avatar
the best brand (IMO) and only brand of the "pointy" kind i use is Malco. you can get them at any HVAC supply house, they all sell Malco. I use the "drill bit" ones for special times when i have to secure to thicker metals.
HVAC1000 is offline   Reply With Quote
The Following User Says Thank You to HVAC1000 For This Useful Post:
jmon (06-03-2013)
Old 06-03-2013, 05:41 AM   #13
HVAC Tech/Owner
Rewards Points: 604
X2
I ran out of self tapping screws on a job and because I was in a hurry I went to lowes and bought a box there....they were junk and did what the OP described.
Technow is offline   Reply With Quote
Old 06-03-2013, 06:46 AM   #14
You, my friend, are awesome!
http://www.homedepot.com/webapp/cata...gry=Search+All
All I needed was a name so I could track them down. I'll just order online and pick them up at the store so I won't even have to hunt them down. Assuming they have them since half the time it says they have 40 in stock and when you get there they have zilch. Thanks so much!
The Following User Says Thank You to mikegp For This Useful Post:
jmon (06-03-2013)
Old 06-03-2013, 07:28 AM   #15
Rewards Points: 282
Glad hvac1000 knew the name. Do you have a local Grainger? They have them as well. In stock.
malco self-piercing sheet metal screws
Construction screws - interior framing miamicuse Building & Construction 15 05-05-2012 05:56 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 02:08 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
