Old 01-05-2007, 02:49 PM   #1
Default Plywood heating duct ?
All references to heating duct materials I have come across use either sheet metal, fiberboard or flex duct, although I have never seen a building code specifying duct materials explicitly.
Is there anything in the building codes that prohibits the use plywood for heating ducts ?
willem is offline   Reply With Quote
Old 01-05-2007, 05:00 PM   #2
You can use floor joists for cold air return.this very common. When it comes to supply air there is a requirements. materials must be "ul aproved ". there are thickness requirements. The man will keep you down by saying it is a "combustable material"
trollmastergeneral is offline   Reply With Quote
Old 01-05-2007, 07:12 PM   #3
General Contractor
joasis's Avatar
I have done remodels that indeed used floor joists for supply and returns....not something I would do. We ended up placing HE equipment and flex duct.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
Old 01-05-2007, 07:22 PM   #4
I understood that UL 181 deals with requirements for ducts.
One of the issues is flame spread and smoke development.
Plywood would not qualify as it has a flame spread index > 20 (the limit for class I).
Does anyone know whether the flame spread requirements apply to the inside alone or both inside and outside of a duct ?
Would it be OK to line a plywood duct with sheet metal ?
Some flexible ducts are lined with plastic, wouldn't this raise issues with smoke / flame spread ?
Old 01-06-2007, 07:02 PM   #5
Thoroughbred Mopar Man
Hi willem
You asked kind of a sticky question there. The flame spread rating on any material is a basic burn through or volitility rating. This is where they come up with the fire ratings from. There is more to do with it than this, but that is the basic skinny on it. As far as linning the plywood, I would not reccomend anything but sheet metal. But that would just be a waste of plywood unless you are using this area for storage and are adding the plywood to keep from destroying the duct. Sheet metal duct is more of a permanent structure than the other forms of ductwork. But keep in mind everything has a usable life.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-07-2007, 06:39 PM   #6
remodeling pro
It's not the plywood specifically that is prohibited, it is flammable materials with specified flame spread rates, and plywood with all of its glue certainly is one of those materials. You could line it with sheet metal and seal all the joints, but why not just use proper ductwork? Using floor/wall cavities is a extremely inefficient thing for either supply or return. You will be paying for the pennies saved now with dollars to operate your system more than necessary for many years in the future.
troubleseeker is offline   Reply With Quote
Old 01-08-2007, 10:51 AM   #7
Got Hammer will Travel
diywoman's Avatar
A quick interjection...I have my duct work coming along the underside of my floor joist..I was tracing it the other night and found that my return was just open to above the ducting and a hole has been cut into the top of the duct work to allow for the air. I thought this looked ridiculous, but are you saying that it's common? I'm trying to find ways to make my heating more efficient. My gas bill is ticking me off. Personally I don't like furnaces because they heat areas equally. I prefer to be able to control each room separately. When I'm asleep at night I don't want my kitchen and living room the same temp as the bedrooms...argh. So anyways, Any helpful hints would be wonderful. "If life were like that" I'd have my whole system set-up automatic...so that at night the vents in the living room and kitchen would close partially to allow less air through, and vice versa when needed. But genious ideas always cost $$$ so now I'm back to the real world and will continue to seal up cracks, windows and all that crap.
Fort Knox this baby!!
DIYwoman
diywoman is offline   Reply With Quote
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
Everybody likes to stay warm during the winter months. However, running your heater for long periods of time can get very expensive. Here are some ways you can stay warm in the winter without using your heater. Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 04:33 PM
Two part question about heating and return ducts J187 HVAC 0 04-20-2007 05:43 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 11:35 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 08:34 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 05:22 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
