Plumbing For Natural Gas ??? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 07:39 PM   #1
Plumbing for natural gas ???
My old house has natural gas fittings for gas heaters but they're not where we would like them to be and two of the rooms don't even have them. What is typically used for plumbing natural gas? steel pipe? copper? PEX? I'm going to get some estimates for the work but I like to learn as much as I can beforehand. Thanks.
DVLCHLD is offline   Reply With Quote
Old 10-08-2008, 07:58 PM   #2
the Musigician
DangerMouse's Avatar
steel for gas so far as i know
DM
Old 10-08-2008, 08:43 PM   #3
How far are you going to run them?
Depending on size it uses 1/2" black iron pipe.
hvaclover is offline   Reply With Quote
Old 10-08-2008, 08:51 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
Either black iron or flexible corrugated stainless is used.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-08-2008, 09:22 PM   #5
I hate track gas line. It looks terrible!
Old 10-08-2008, 09:35 PM   #6
Black pipe and gasflex are the most common. Gasflex is expensive but it installs real fast. I use both depending on the situation.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 09:48 PM   #7
Black pipe is neater looking and cooler to use.
~snicker~ any of you pros ever see a dry waller run a screw in to the flexable stuff that was run inside a wall.....that was one dry waller that gave up smoking lol
Old 10-08-2008, 09:58 PM   #8
~snicker~ any of you pros ever se a dry waller run a screw in to the flexable stuff that was run inside a wall.....that was one dry waller that gave up smoking lol
I'm a black pipe guy myself. I just seems much safer.
I use flexpipe for short runs and never in the wall.
Usually it is when I am in a hurry and being lazy...
Old 10-08-2008, 10:06 PM   #9
Thanks, black pipe it is.
Old 10-09-2008, 12:31 AM   #10
Registered User
Termite's Avatar
Also, don't arbitrarily assume that 1/2" pipe will be adequate to supply the appliance(s). In many, many circumstances it will not. Gas pipes must be sized, which is a complicated process that your plumber hopefully understands.
Old 10-09-2008, 12:36 AM   #11
An inspector?
Cool! Are we allowed to pick on him?
Just funnin' guy. How ya be to night?
Old 10-09-2008, 12:38 AM   #12
OP didn't respond when i asked what they were hooking up but they did mention a water heater.
Old 10-09-2008, 02:03 AM   #13
1921 Sears&Robuc
Just a do-it-yourselfer's opinion, you can run your own black pipe(black iron) It really isnt that difficult either! Your local supply store will have all the sizes you could imagine, to make this job as easy as pie. I just finished the install of a 54ft run(from meter to furnace), with three bends(elbows). It really wasnt that difficult! If you can read a tape measure you can map and measure your run and put it where you want it! Thats exactly what i done, i drew a map of measured lengths of each run and exactly where i wanted it to go. I only missed with one measurement by 1" and well black pipe has some flex for those small mishaps(miscalculations). So a simple pull in the opposite direction made the a perfect fit for the install to go excactly where i wanted it to go!
So do it yourself, you will have a blast! Get yourself a couple of pipe wrenches, and a tub of pipe-dope, and enjoy yourself when your done enjoy the fruits of your labor! Besides your labor=$0.00 thier labor+$65.00 hr. you do the math!
My house, a 1921 Sears-Robuk 1 1/2 story 4 bedroom, 2 bath 1975 sqr ft house! Ordered March 1921, delivered via: railcar 1922, assembled October 1922! Ignorance is not having the knowledge of', Stupidity is having the knowledge of' and not using it!
MrShadetree0222 is offline   Reply With Quote
Old 10-09-2008, 08:26 AM   #14
I'd be curious to see wht you size you ran. Allowances must be made for the amount of flow in cu in for each.
The pipe can.t be all one size and feed a WH and furnace ect
Old 10-09-2008, 08:49 AM   #15
Registered User
Termite's Avatar
Better pack a lunch! I'm pretty crafty!
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 08:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 12:38 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
