Plumbing Copper For HVAC Refrigerant Lines? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 05:44 PM   #1
plumbing copper for HVAC refrigerant lines?
I realize one issue is lack of soldered joints on a long tubing set but other than that is there a problem with using regular plumbing copper for HVAC refrigerant lines? Are the HVAC tubing sets dried or something? Would it matter which type of copper tubing (M or L I think) was used?
Mike in Arkansas is offline   Reply With Quote
Old 03-20-2010, 06:06 PM   #2
AC line sets are cleaned, capped and have a nitrogen smell. Water line copper is open on the ends in storage so gets all kinds of dirt and oxidation inside.
Old 03-20-2010, 07:04 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
We have to use thicker type "K" for HVAC as the discharge pressure is well over 200 psi.
http://www.engineeringtoolbox.com/as...bes-d_779.html
Old 03-20-2010, 11:04 PM   #4
Home Air Direct's Avatar
What Yuri Said. Only use K Tube that is "Capped". Now, the fittings are another thing. The fittings (elbows, couplers, etc.) are the same as the plumbing fittings, just remember that refrigeration measures OD (outside diameter) and plumbing uses ID (inside diameter). So, a 3/4" refrigeration fitting is actually 5/8" in the plumbing world.
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 03-21-2010, 12:00 AM   #5
Good Luck
HVAC long radius elbows
Plumbing short radius elbows
pomelo is offline   Reply With Quote
Old 03-21-2010, 12:03 AM   #6
Good Catch. You are correct. I left that out. The fitting grades are the same, but the LR is the standard for Ref.
Old 03-21-2010, 05:20 AM   #7
An old Tradesmen
Rewards Points: 6,092
As others have said. Refrigeration copper lines are cleaned and dehydrated.
Type M copper is not approved for use as a refrigerant line in any area.
Old 03-21-2010, 09:36 AM   #8
Hvac Pro
yuri's Avatar
Uhh. We have regular radius and long radius elbows. The long radius are 2-3x the price. Ouch. A standard radius elbow is longer than a standard plumbing elbow.Usually there is a S or M for Streamline or Mueller who make most of the fittings, stamped on a refrig fitting.
http://www.muellerindustries.com/
http://www.muellerindustries.com/wudfs/curacrf.pdf
Old 03-21-2010, 03:09 PM   #9
Thanks everyone. Guess, I'll just go with the refrigeration set.
Old 03-21-2010, 09:52 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
what he said
plummen is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Question re: plumbing air lines in my shop Termite Plumbing 12 02-14-2010 11:37 PM
Should I buy an old house with copper plumbing in the slab? waxdart Plumbing 8 07-04-2009 08:16 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 10:54 AM
