Plugging Ceiling Air Leaks Before Insulating Attic? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 03:22 PM   #1
dvs
Question
Plugging ceiling air leaks before insulating attic?
I am in Seattle and we clearly need more insulation in our attic. We currently have 60-yr old loose fill that's about 3 inches thick.
I've been given some advice about plugging air leaks before adding insulation. Reason given is that it's important to stop the warm, moist air that's in our house from getting into the attic once we have 18-24 inches of insulation. Apparently once we have all the insulation, the moist air that's currently escaping through the 3 inches of fluff we have now will suddenly get trapped in the new insulation and lead to much mold growth.
I'd hire a company to plug the holes, which will be pretty expensive.
Any thoughts?
dvs is offline   Reply With Quote
Old 12-02-2010, 04:43 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
3M expanding foam in a can (draft seal stuff) at HDepot. Make sure it is fire rated and not touching any electrical pot lamp fixtures if you have them. They need proper clearance from any insulation or they overheat/catch fire.
The Following User Says Thank You to yuri For This Useful Post:
dvs (12-02-2010)
Old 12-02-2010, 04:44 PM   #3
An old Tradesmen
Rewards Points: 6,846
Always benefits you to seal any air leaks you can. Helps to keep your humidity in check.
The Following User Says Thank You to beenthere For This Useful Post:
dvs (12-02-2010)
Old 12-02-2010, 04:48 PM   #4
dvs
I'm sure there is some benefit...I am just trying to quantify that benefit. It will either be expensive for someone else to do or a lengthy project for me to do. So, if it improves my efficiency by 5%, it's not going to be worth it.
On the other hand, if it prevents mold and rot from entering my attic, it's probably worth it.
Old 12-02-2010, 05:14 PM   #5
An old Tradesmen
How is the humidity in your house?
Sealing could be 5%, or 25%, depending n how much leakage you have.
Old 12-02-2010, 05:44 PM   #6
Registered User
Rewards Points: 5,466
The sealing stops heated air from creating ice dams: http://bct.nrc.umass.edu/index.php/p...ting-ice-dams/
The attic ventilation removes any heated air from below, required in our location per Code: (below you near Tacoma). http://www.fpl.fs.fed.us/documnts/pdf1999/tenwo99a.pdf
A few guides on air sealing: http://www.familyhandyman.com/DIY-Pr...s/Step-By-Step
http://oee.nrcan.gc.ca/residential/p...ap4.cfm?attr=4
Gary
Tags
air leaks , attic insulation , mold
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Insulating a Porch ceiling Mark Harvey Building & Construction 1 01-08-2010 10:44 AM
Sealing or insulating attic fan Blondesense Building & Construction 11 12-12-2009 02:39 PM
rounding attic ceiling plaster luci468 Building & Construction 2 05-28-2009 08:36 AM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
