Plug Basement Weep Holes For The Winter?? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 09:47 AM   #1
plug basement weep holes for the winter??
I have a new home built in 2007. It has a full basement with the lowest course of cement block having weep holes between each block. They are actually slits where it looks like no mortar was applied. I understand that this to allow water that may be have seeped into the block to escape into the gap between the basement floor and the wall
My question is I notice that there is a lot of cold air coming through these slits into the basement. Would it make sense to try and plug these for the winter and they remove the plugs in the Spring?
captjackny is offline   Reply With Quote
Old 01-27-2009, 07:23 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Ask your builder why they are there and if plugging them will cause any problems/warranty concerns.
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 12:17 PM
How to best cover weep holes on a brick wall smcmurrey General DIY Discussions 27 10-12-2011 11:33 PM
Plug up holes in wood fw2007 Carpentry 5 09-10-2008 02:38 PM
Basement holes WinnipegCouple Building & Construction 2 09-02-2008 08:12 PM
