| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Truss Rod: Fender Stratocaster Setup
by Expert Village
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Remodeling a Garage: General Construction
by Expert Village
We're going to try first, to pull their existing duct work. I've checked with all the mechanicals, it looks like this air conditioning system can carry the load, of this extra square footage. We're going to try that first, if we need to then supplement... Read More »
How to Set Up Second Duct Blaster for Home Duct Testing
by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. The reason we are setting up another duct blasting, we are going to go ahead and test the duct work again. You... Read More »
Checking Home Insulation Thickness
by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
What are External Bearing Cranks on Mountain Bikes?
by Expert Village
It appears that the mountain bike industry is moving towards external-bearing, two-piece cranks. So these cranks are better because you've got larger bearings that are wider spaced, so they're stiffer and see less weird, tortional loads and wearing... Read More »
