Plenums - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 06:19 PM   #1
plenums
i'm buying a goodman aruf18b14 air handler,does anyone know what size plenums I would need ...would like to buy plenum when I buy the air handler...
buck545 is offline   Reply With Quote
Old 04-29-2013, 06:23 PM   #2
An old Tradesmen
Rewards Points: 6,846
Specs for that air handler are on Goodman's website.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-29-2013)
Old 04-29-2013, 06:54 PM   #3
tried
I know, but with the way they have the diagrams I couldn't figure it out...
Old 04-29-2013, 07:14 PM   #4
An old Tradesmen
Supply opening 11X13 1/2
Return opening 13 1/8X17 5/16, if butting against the bottom of the air handler, then its 15 1/2X22
Old 04-29-2013, 08:15 PM   #5
great
thank you!!!!....just a couple more questions than i'll be all set.
Old 04-30-2013, 05:21 AM   #6
not finding that exact size plenum, the closest that I can find on line is 14by 14 or a 17 by 12....which would be a better fit...
Old 04-30-2013, 05:27 AM   #7
An old Tradesmen
For supply 14x14
Old 05-01-2013, 05:41 PM   #8
now i'm going to be just butting up against the bottom of the unit for my supplys, what size duct would I need for that? and thanks again for the help
Old 05-01-2013, 08:43 PM   #9
An old Tradesmen
Unless in a down flow configuration, the bottom is the return.
14X14 for supply plenum if your just butting against the air handler.
plenums buck545 HVAC 5 03-25-2013 03:32 PM
Questions about my return plenums Mijotter HVAC 3 12-07-2012 12:17 PM
Installing Registers in Plenum's? BIG1RED9 HVAC 3 07-31-2012 04:51 PM
I need measurements for plenums TANNY HVAC 6 01-17-2012 10:12 PM
running extended plenums side by side BlueBSH HVAC 3 07-11-2011 07:13 PM
