Plenum Transistion - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 09:16 AM   #1
plenum transistion
I need to extend the plenum downward enough so I can get it off the floor joist and insulate it. It is a rectangle trunk (didn't measure it yet). Should I be able to find prefabbed sections of this trunk or have to make my own transition? I'd really like to just transition to a new trunk all together and replace all the old runs etc.
kevsprojects is offline   Reply With Quote
Old 07-28-2011, 09:23 AM   #2
fabrk8r
fabrk8r's Avatar
If you have any sheet metal shops in your vicinity they should be able to make you an offset/transition fairly quickly and inexpensively if you provide the proper measurements.
The same for the duct. Most shops can even insulate the duct internally if you'd prefer.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 07-29-2011, 06:59 PM   #3
I did find a shop in my town here that I hadn't thought about until now. Ill get specs and see what I can produce! thanks.
plenum dimensions Hermand HVAC 5 03-10-2011 01:24 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
