Plenum Rebuild Vs. Replace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 01:44 PM   #1
plenum rebuild vs. replace
Hi:
We are in inspection negotiation with a home that we want to purchase. Our inspector noted that the plenum has been in contact with the soil and the bottom has corroded away. The seller's repair agreement says that it will rebuild the plenum. We have no experience in home repairs, much less HVAC--is rebuild fine or should we ask them to replace it? We are waiting to hear back for clarification about the wording, but I would like to know ahead of time if rebuilding it is fine.
They are hiring a local heating and cooling company that has excellent reviews to do the repairs.
thanks!
jennifleur is offline   Reply With Quote
Old 08-11-2011, 02:10 PM   #2
JJboy's Avatar
The replace will be rebuilding
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-11-2011, 02:20 PM   #3
Now I'm even more confused.
"Rebuild" to me means they leave the original structure and replace just the corroded part.
"Replace" to me means that they will remove the original plenum and put in a new one.
But maybe "rebuild" means something different in this context that I'm missing?
Old 08-11-2011, 02:38 PM   #4
JJboy's Avatar
Depends on the material that was used.
Old 08-11-2011, 02:57 PM   #5
lol come on guys, give a straight answer, it is much more convenient to replace entire plenum because even if they do a VERY good job, you dont know if something in the plenum has died (i.e. mouse, rat, hippopotomus etc.) thus it will cause a stench and will cost you even MORE money to replace it if that is the case.
Final Notice is offline   Reply With Quote
Old 08-11-2011, 03:56 PM   #6
Nothing smells like a critter caught in the heat strips...
Rebuild or replace will depend on the material used to make the plenum. But more than likely it will be replaced. Its usually easier than trying to attach new material to old..
Now if the plenum runs for a long distance then just the damaged section would be replaced. Which is all that would be needed.
Master of Cold is offline   Reply With Quote
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
cost to replace return boot and filter box..... BlueBSH HVAC 5 08-06-2010 09:50 AM
Basement Flooded ... help me rebuild! hellothere123 General DIY Discussions 3 08-06-2010 03:38 AM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
