Plenum Re-sizing Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 11:07 AM   #1
plenum re-sizing question
I am updating my downflow furnace and air conditioner coil which will sit on top of an original old plenum which is oversize for this new unit. Rather than replace all of the ductwork, I was just going to frame in the new required size with wood, rebuild the subfloor over it and then install the coil and furnace. Now I am questioning my thoughts, is it okay to have bare wood (my framework) inside of the old sheet metal plenum or is this considered to be a fire hazard with the hot furnace above and blowing down through it?
Thank You in advance to all who will share their expertise.
jlsdcen2 is offline   Reply With Quote
Old 03-05-2012, 03:48 PM   #2
No wood inside the plenum. Have someone make you an adapter out of metal!
JSCOTTYB is offline   Reply With Quote
Old 03-05-2012, 05:41 PM   #3
Rewards Points: 304
you can't use wood need to have adapter form metal made
ben's plumbing is online now   Reply With Quote
How hot does it typically get in the main plenum of a furnace? Red Squirrel HVAC 15 02-29-2012 03:32 PM
plenum installation question Talgonadia HVAC 3 10-06-2011 02:00 PM
sizing choice on system upgrade raylo32 HVAC 49 08-21-2011 08:23 PM
Sill Beam Sizing Question Erocku Building & Construction 8 02-27-2009 04:50 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
