-   -   Plenum Needs Repiar (http://www.diychatroom.com/f17/plenum-needs-repiar-26206/)
pearlbeer 09-03-2008 09:53 AM
Plenum Needs Repiar
1 Attachment(s)
Hi. I just bought a house and need to make a few repairs. I'm in Texas, so the first order of business is to repair the faulty plenum in my attic before I spend a ton of money trying to cool the entire state.:no:
I've attached a picture. Is standard duct tape the best way to repair? Sure seems either a) low class or b) too easy
Thanks!
Steven62 09-03-2008 11:11 AM
Looks like insulated panels made into a plenum. I used to install A.C years ago, and I was skinny and strong enough that I earned the loft title of "Attic Rat" so I have seen and done quite a bit in that realm.
This is how I would do it:
Get some sheet metal of sufficient quantity to make an end (where I see what looks like two flexible ducts attached) and get your tin snips out....
Make collars for the flex duct and cut out appropriate holes in the end you made and install.
Use self tapping sheet metal screws to attach the collars, and the duct, then tape up really well.
I wish I could sketch a picture of what it would look like when done....
Next, you will have a good size flange (at least 2") to surround and overlap the "box" end, and put screws long enough to penetrate the thickness of the insulated board.
Then tape, tape, tape ( Good name brand duct tape)
I am from Alaska originally, and what they say about us is true:
We buy duct tape by the case
1610 CUB 09-03-2008 11:18 AM
IMO you need to get the weight off the side plenum where the flex duct comes off. Then sense the duct board is dirty you will need to clean it up so tape will stick. Get some 2 or 3" wide foil tape to make the repair. It looks as if the flex ducts have been hard cast ioto the duct board, you can get hard cast at about any sheet metal shop. Hope it helps........ j
Steven62 09-03-2008 12:04 PM
Cub, I see what you see, I think.
dirt and/ or moisture has caused a lack of adhesion where it is taped, but I had overlooked the way the flex "Hangs" and pulls.
I still think I would use sheet metal, but I am getting old, or so they tell me... So I may be speaking of things that exist in my mind only..:jester:
1610 CUB 09-03-2008 12:49 PM
The trouble with trying to put sheet metal on is there is nothing to screw it to. Now if you wanted to open up the duct and put in an inner piece of metal so the outer piece has something to screw into ..... OK but I don't like being in a hot attic any longer than necessary! Get the foil tape and the 'Hard Cast' :thumbsup:
pearlbeer 09-03-2008 03:08 PM
Thanks. Those were pretty much my thoughts. Sounds like I'll be in a hot attic with a little acetone and some foil and duct tape.
Not really understand the additional 'hard cast' that I might need.
I can certainly look to see if those ducts are pulling on the plenum causing seperation. I have a feeling someone was just sloppy when they moved their crap of the crawl space and whacked my plenum. Oooooww...my plenum hurts.:(
1610 CUB 09-03-2008 04:13 PM
here ya go get a tube of this http://www.hardcast.com/PRODUCTS/pdfs/DS321.pdf you should be ableto get it at any sheet metal shop it will work!
